Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
That's exactly right. What speeds are you getting in the loft without the antenna? By the sounds of it you don't need that external antenna at all.It feels as though the modem is using the external XPOL antenna in addition to the modem as opposed to using it instead of, really confused.
Maybe I have misunderstood the posts then, I will read up about rolling back.That's exactly right. What speeds are you getting in the loft without the antenna? By the sounds of it you don't need that external antenna at all.
Thank you very much@Monkeyrear, what version of MC801A are you using? Three Mobile has its own firmware and is currently B04. The ones sold by Sotel have German T-Mobile firmware and its current firmware is B09 although it has previously sold B06. If you have the latter, do not attempt to upgrade or downgrade the firmware. People on this forum have tried and bricked their devices.
If you have the Three mobile version then Three is responsible for any changes in service level.
As for power extension, instead of running a long mains cable you might consider a DC 12v extension cable instead.
I used this with my Huawei for a while.
Having exactly the same problem with the same router on B09 FW (received Friday 10th), except I think it's happening about once every 15 mins, if not more frequentlyHello all.
I Received my Three ZTE on Wednesday (8th June) - it's running B09.
My pc is connected via ethernet, my laptop (and various other devices) via Wi-Fi.
It sits on an upstairs windowsill with line-of-sight to the 5G tower around 500m away. The 'suggested position' function of the gui says the position it's in is 'perfect' and I can get between 650 to 950 Mbps (testing right now it's 887).
However, at least once a day the internet connection has been lost, but all lights on the front are still lit white. After around a minute or so, the internet connection is restored to both ethernet and Wi-Fi without any intervention from me.
Today, it dropped out at around 19:20 and I had to restart it via the GUI at 20:00.
I have looked at the 'hidden' pages but I can't seem to find any router connection log details. I was wondering - is there a log page I can view which might have some information on why this is happening?
I've been having similar issues. I am really happy with the connectivity, but the frequent reboots (multiple times a day) are really annoying.Hello all.
Date and time | Status |
06/13/2022 12:48:22 PM | Online |
06/13/2022 12:48:11 PM | No internet connection |
06/13/2022 12:48:05 PM | No internet connection. Wi-Fi/Ethernet OK |
06/13/2022 12:47:57 PM | Online |
06/13/2022 12:47:15 PM | No internet connection |
06/13/2022 12:47:14 PM | No internet connection. Wi-Fi/Ethernet OK |
06/13/2022 10:30:16 AM | Online |
NP109SY@Skip_2022 where in the country are you, which postcode, where are your local masts?
On CellmapperNP109SY
Local mast:
Check your network coverage | Support | Three
Check network coverage for 4G, and 5G in your area. Our 4G network covers 99% of the UK population (outdoor coverage). And we’re the UK’s Fastest 5G Network.www.three.co.uk
yep - that's the one I think
Where are you getting that data?Today's disconnects so far:
Date and time Status 06/13/2022 12:48:22 PM Online 06/13/2022 12:48:11 PM No internet connection 06/13/2022 12:48:05 PM No internet connection. Wi-Fi/Ethernet OK 06/13/2022 12:47:57 PM Online 06/13/2022 12:47:15 PM No internet connection 06/13/2022 12:47:14 PM No internet connection. Wi-Fi/Ethernet OK 06/13/2022 10:30:16 AM Online
not recommended.chrome extension 'internet connection monitor'
Internetverbindungsmonitor
Überwachen und testen Sie die Internetverbindung. Erkennen und protokollieren Sie, wenn das Internet nicht funktioniert, auch bei…chrome.google.com
