Diggedy
Is anyone using on of these routers on the three network and also with a mesh system?
Mine used to work well with great speeds but now I get a lot of lag when streaming. A speed test shows its fine (70/40 ish), ping is below 100 although it used to be better but everything I stream is buffering.
It used to work fine until a power cut, I assumed the router had been damaged somehow as when trying to log in to the admin page it would freeze and I had to switch it off on to allow me to log in but would freeze after a minute so had it replaced.
Even the new one has done it but I disconnected my mesh network (bt whole home) and the admin page seemed very responsive. Now I'm wondering if either the power cut did something funky to the mesh network or somehow there's a conflict of some sort with the mesh or if the router simply can't handle the number of devices on the network and the power cut is a red herring.
Anyone had similar experiences?
